What's up with the 'Find' command?
Home Forums Discussion Forum What's up with the 'Find' command?
Viewing 6 reply threads
    • #444539
      Dan Schaeffer
      I like to cram a lot of data into the Notes field; excerpts from outlook emails, etc, but I’m finding that I’m unable use the Find command to find tasks that have the target text that I’m seeking – even when I’m looking right at it. When I search this way I choose ‘Look in field > selected > Notes’ match case off and it doesn’t matter whether I’m searching up or down. Does anyone have any insight as to why Project is unable to find Notes text that is clearly visible?
      Dan
      PS. The text that I’m searching was pasted into the notes field as unformatted text.
    • #444541
      Jigs Gaton
      I too am a heavy notes field user here, and I don’t seem to have any problems. I am using MSP PRO 2019 MSO (16.0.13029.20342) 64 bit. Could be an issue with ur version? Also, u have the Notes field added to the view u are searching through, right?
    • #444543
      Dan Schaeffer
      Jigs,
      What I’m finding online is that only the first 255 chars are searchable. Are you finding that you can search more than that? I’m using MSP Online Desktop Client MSO 16.0.12527.20612 32-bit
      Dan
    • #444569
      Jigs Gaton
      Dan, I think u found a bug *or is it a feature where MSP only searches the first 255 characters and then bails in any field string. Congrats! I wonder if they still give out mugs and tees for finding these? Good luck.
    • #444570
      Jigs Gaton
      But the bug makes sense, MSP was coded back when I was using a DOS computer and had to load the app on a floppy disk.
    • #444616
      Dan Schaeffer
      …so you’ve confirmed v19 is only searching the first 255 chars?
    • #444702
      Jigs Gaton
      yes, exactly so. I am also asking my pal over at http://www.projectplan365.com to investigate. If it’s fixable, he will most likely fix there.
