Home › Forums › Discussion Forum › Task bar color based on resource assigned
I am using Ms-2016, I would like to know if the color of the task bar can be changed depending on the resource assigned. Ex: If Paul is assigned to a task the bar becomes Green whereas it will turn yellow if Jim is assigned.
How can it be done?
Thank you!
Sorry, not really unless someone has a trick I don’t know of.
