Saving MS Project w/filters on
Home Forums Discussion Forum Saving MS Project w/filters on
    • #319612
      Brian
      I heard that if you save your project schedule with one of your filters “On”. It will create some background “corruption” in your schedule and make it a larger file.
    • #319677
      I personally haven’t heard that before. Files do get big especially when entering actual time, and I heard of files gaining bloat, but I haven’t found that to be as much of a problem with recent releases and not specifically due to filters. It’s certainly a conclusive answer but I hope it helps…
    • #320224
      Brian
      Thanks!! Can anything be done about the bloat?
    • #320236
      You might want to try this blog for starters. It was written a while ago and like I said I don’t see it much in current versions, but it might help.
      https://project.mvps.org/faqs.htm#Handling_project_file_corruption_and/or_bloat
      Good luck
