PSI programming and getting Project UID manually
Home Forums Discussion Forum PSI programming and getting Project UID manually
    • #384439
      Guhan
      Our project use Microsoft Project to track efforts. I am in process of accessing the MS project via WCF/Web services using PSI.
      I understand that there are different GUID for main project and each parent/sub tasks created under it.
      I want to know if there is any option to view the main project GUId manually inside MS project(which displays in Active windows title bar). Basically I need to see the GUID for the task outline level 0.
      Task GUID can be viewed by choosing GUID column in the MS project for each task we create. This will list only task outline level 1 and above.
      — Thanks & Regards, Guhan
    • #384456
      Sorry, not that I know of.
