Project Server View Setting
Home Forums Discussion Forum Project Server View Setting
Viewing 7 reply threads
    • #387716
      Wesley
      I’m having a problem in Project Server 2013. If you go into the project and schedule, you see all the content based on what view setting you are on. When you go to Edit, In Browser, it takes off a few of those lines. This only happens in certain jobs but not all. It looks to be a filter problem but have verified it is not because it happens in views that do not have filters. Any information would be very helpful.
    • #387815
      Wesley, is there any similarity in the tasks that don’t show up in edit mode? Are they inactive tasks?
    • #387834
      IT Helpdesk
      Yes. There are 5 hours columns for budget work, actual work, remaining work, projected work and work variance. All 5 of those hours columns have to show “0” for that row to not show up.
    • #387835
      Sorry Wesley but I have no idea why that would happen. Assuming that the PWA view you are looking at is from the Task table (instead of the Resource or Assignment table), there is no reason I can think of to not show these tasks. One question, does this happen on every PWA Project view that shows the Gantt Chart?
    • #387838
      IT Helpdesk
      It is from the Task table under the Data section. It is not in every view. I thought it was originally but some are working.
    • #387845
      Recreate one of the views that don’t work and see if that fixes the issue…??
    • #387856
      IT Helpdesk
      We tried that as well and it didn’t work unfortunately.
    • #387857
      OK, then it must have something to do with the view. What is different between a view that works and a view that doesn’t? Something has to be different that is making a view not work. I have no other suggestions for you without looking at it myself. Hopefully someone else has some thoughts. Something is different that makes one work and one not work, but I have no other suggestions without looking at it myself. Sorry about that.
