Project Online Read
Home Forums Discussion Forum Project Online Read
    • #416189
      David
      Just this week I started noticing an issue while checking out a project from PWA (Project Online). Normally I would get one yellow message bar across the screen with the message.
      READ-ONLY This project was opened in read-only mode. Check Out
      Now whenever I download a project from online I am getting 3-6 of the same messages duplicated. Yet only one works to check out the project for editing. The others do nothing. Which then forces me to close all of the messages manually.
      Has anyone else experienced this issue?
      I did try to re-install project but did nothing to fix the problem. It doesn’t happen when loading files not downloaded from Project Online.
      David
    • #416190
      David, I haven’t heard this one but if you don’t get an answer you can always submit a ticket to Microsoft. I know some people have gotten poor responses but I’ve always gotten an answer sooner or later. Good luck…
    • #416191
      David
      Thanks Larry. Have a great day.
      David
    • #416204
      Tom
      Our whole PMO group is encountering the same thing. Project functions normal outside of getting 2-7 yellow “Check Out” boxes and that you have to close them all manually with the “X”.
      I am wondering if the bug came out in version 1907? We are setup for auto updates.
    • #416205
      Then it is a problem with the server software. I would hope that Microsoft has seen this one before and suggest giving them a call.
