Problem Syncing Sharepoint & Project 2013
Home Forums Discussion Forum Problem Syncing Sharepoint & Project 2013
  • This topic has 3 replies, 2 voices, and was last updated 10 years ago by Anonymous.
    • #355270
      Tun
      New to SharePoint and Project, so this might be an elementary question.
      I’ve created a task list in SharePoint and successfully synced to Project Pro 2013. I’m having trouble with two things…
      1. Along with each task, I have a group of resources that might complete the task. I’ve added a “Completed By” and “Completed Date” column to track who actually completes the task and when. I’ve tried adding in SharePoint and syncing back to Project, and vice versa, but can’t get that info to sync. Can you tell me how to do that, or if there’s a better option?
      2. I’ve set predecessors in Project, but they won’t sync up to SharePoint.
      Any help is appreciated!
    • #355294
      Tun,
      Welcome to Microsoft SharePoint and Project, and I hope you enjoy the trip. For number one: In Microsoft Project, go to File / Info / and you will see Map Fields next to the Save button. That is where you map fields between Project and SharePoint. Predecessors should synch, not sure why they wouldn’t. Let’s start with number one and see if that helps. Maybe that will also fix number two…??
      Thanks…Larry
    • #355334
      Tun
      Thanks, Larry – that solved both problems! I appreciate the quick help.
    • #355359
      You’re welcome, glad it helped…
