Microsoft Project 2016 issues Format Painter, cant Move columns and rows
Home Forums Discussion Forum Microsoft Project 2016 issues Format Painter, cant Move columns and rows
  • This topic has 18 replies, 2 voices, and was last updated 5 years ago by Shax.
Viewing 16 reply threads
    • #391074
      Anna Anderson
      Microsoft Project 2016 had been working fine until Mid March 2016 for atleast 2 months.
      Suddenly, some functions that were working before don’t work now.
      Format Painter doesn’t work. Moving rows by clicking and dragging doesn’t work. Moving columns don’t work. Anyone with ideas?
    • #391121
      Anna, as strange as this is I think I might know what’s happening. Go to File / Options, and select the Advanced tab. Part way down under the Edit section, check to see if the Allow cell drag and drop checkbox is selected. It’s supposed to be, and will cause the behavior you are seeing if it is unselected. Let me know if that works. Thanks…
      • #397482
        Tim
        Well, this issue is STILL an issue as of June 8th, 2016. I am, however, updating Microsoft Office 2016 to see if it will resolve the issue… I’m hoping …. Hoping and praying this issue will be fixed…. It’s annoying …
    • #391169
      Neil
      I have the exact same problem. I have already checked on the configuration checkbox you are talking about. It was checked. I tried unchecking it, closing, reopening, checking it again to see if it triggered anything, but no. Still does not work for me.
      • #391178
        Sharon Fry
        Sorry, Neil, I hadn’t refreshed the page since I first opened it so I didn’t see your post when I submitting mine. 🙂
    • #391177
      Sharon Fry
      Anna, thanks for asking this last night as I had a couple of students in my Project 2013 class today that had 2016 installed – and they had the same issue.
      Larry, I checked on their machines, and “Allow cell drag and drop” checkbox is selected (checked) – so that is not the issue.
      Based on the change in behavior that Anna described, my guess is that an update caused it. The question now is whether that was intentional on Microsoft’s part, but since it also “broke” Format Painter, I’d think not.
    • #391542
      David
      Issue – Microsoft Project 2016 issues Format Painter, cant Move columns and rows
      I have the exact issue as personnel on the below link. I spent almost six hours on the phone today with Microsoft and all I got was a run around from customer service agents that either no clue what they were talking about or were not trained. I was also disconnected several times and had to start the process over and over again. It is costing me time and money!!!
      See the below link and provide a fix please – very frustrated!
    • #392056
      David
      I have the same problem that I am now unable to drag either task rows or columns to a new location. I am new to 2016 so wasn’t sure if this was a revision but from the posts, I think it is a new problem.
    • #392057
      OK, now it just happened to me with my Project Pro for O365. Please don’t tell me it’s contagious…!! It still works fine on my Project 2010 version. Wow, now that’s a real bummer…
    • #393045
      Wim
      I have something similar with project pro 2016 x64
      I can still move columns, but I cant actually select where they need to go.
      They appear somewhere way down on the ghant chart. It’s like there is a scaling issue with the mouse coordinates or something.
    • #393467
      Ed Wilko
      I have the exact same problem. I use to be able to drag a row to another location and i can no longer perform this action. Have checked the “Allow cell drag and drop” and it is checked already. Have tried numerous times to uncheck and re-check.
      Please someone solve this issue as it is extremely frustrating
    • #393814
      Josh Elvander
      I also observed this issue, and share the frustrations.
    • #395620
      Dan
      I am also having the same problem on 2 different install of Project 16. Coincidentally around the same time frame I have a problem with Windows 10 Start Menu, and the windows tiles. It seem that when I add a new program tile it some how does not get indexed properly, so the start menu and Cortina both stop working. The only solution is to add a new user and rebuild all of the tiles. Microsoft is aware of the problem but like our Project problem not time frame for repair has been published.
    • #397033
      Mo
      I just installed Project 2016, and found this problem. Is there a solution to it yet?
    • #397089
      Saif Ahmed Syed
      Is there a solution yet?
    • #397483
      The good news is that it is fixed on my O365 version (Project Pro for O365). That probably means it will be sent out soon through an update. I am also glad to see that it is being fixed.
    • #399160
      Dan
      It seems that Microsoft has resolved this issue with their late June updates. I can now move columns and use the format painter again.
    • #413949
      Scott
      November 2018 – problem still exists. I’ve been using Project for twenty years, and with every single release there’s always been an issue. Surely something as basic as rearranging the order of columns would be noticed during the testing phase.
    • #418235
      Shax
      Still an issue in 2020!
