ID numbers, Outline numbers etc
Home Forums Discussion Forum ID numbers, Outline numbers etc
  • This topic is empty.
Viewing 0 reply threads
    • #485579
      James Welsh
      When I create a schedule I like to use the outline numbers. When I set up predecessors and successors, the numbers are referring to the ID numbers at the left of the UI. Unfortunately, when you copy and paste the schedule into Excel the outline numbers and IDs don’t get copied. so, I add a separate column that has the outline numbers so far so good. But the predecessors e.g 14ss, 32fs, etc. are listed referring to the ID#, not the outline number. Is it possible to have a column with the ID#? then when I put the schedule into Excel the team would be able to follow along.
