I’d like sort order saved as part of my custom view – is this possible?
Home Forums Discussion Forum I’d like sort order saved as part of my custom view – is this possible?
Viewing 8 reply threads
    • #481732
      Dan Schaeffer
      Is it possible to define a custom view that uses a specific sort order whenever it’s invoked?
      Dan
    • #482035
      Joseph Wharton
      I don’t believe this is possible. Tip: remove Summary headers (Format / Show/Hide / Summary Tasks) for a complete Sort of all tasks.
    • #482036
      Jerome
      Yes it is possible.
      Apply your sort criteria and then save a copy of your current view (lets say you name it “Sorted View”).
      Anytime you select this “Sorted View”, the sort criteria will be applied.
      =jerome
    • #482148
      Is there a method to apply to filtering as well as sorting ?
      For example, can a filter be applied and saved as part of the current view and then save as “Filtered View”.
      Specifically : Filter = Show Tasks Between Task ID 50 and Task ID 100.
    • #482204
      To save your filter with a view, go to the View tab and click on Gantt Chart dropdown menu in the Task Views group.
      Then click on More Views and in the More Views dialog, click on Copy button.
      This will open the View Definition dialog. You can now give the name “Filtered View” and in the Filter dropdown, select your special Filter. Remember to select the “Show in menu” checkbox so that this View appears under your views list (Gantt Chart dropdown).
      This new “Filtered View” will also follow the sort criteria that was applied before it was saved.
      If you still struggle with the outlined steps, let me know at plannersplace.com and I’ll produce a short video for you.
    • #482297
      Thank you for this.
      I did create the View with a “Task Range Filter” applied and the system (MSP 2013 Std.) does work however, the Task Range (Tasks Between Task ID 50 and Task ID 100) is not stored, so the system pops up with the Task Range Dialog Box asking for the Task IDs. I suspect this might be the same for Date Filter too…. although other filters like “Milestones” did work OK.
      KMD
    • #482299
      If you use the default “Task Range” & “Date Range” filters that come with Microsoft Project, you will always be prompted to enter range values, since these are dynamic filters.
      Create custom Task Range or Date Range filters and they will be saved with your View. An example of a custom task range filter shown below.
      Custom Task Range Filter
    • #482395
      Tried your method and it worked perfectly… thank you… I have been looking for this technique for some time. KMD
    • #507760
      I also want to know is it possible to define a custom view that uses a specific sort of order whenever it’s invoked and I am glad I have found your post. Thanks for sharing my question answer in brief, it was easy for me to understand your post. I also tried your method and it is actually working. Now, I am all free and will read samples on this https://www.topessaywriting.org/samples/entrepreneurship link because my brother needs help with his essay assignment. I am also not that good at writing an essay that is why I am searching for it online.
