How to move linked .mpp files?
Home Forums Discussion Forum How to move linked .mpp files?
    • #478407
      Bob Cunningham
      I recently started at a new company. So far all of my .mpp files are on my own computer- and we all know what a bad plan that is.
      I would like to move to a company server, however most of my files are linked to a Resource .mpp file and from what I understand those links include the local path.
      How to I move my .mpp files to another directory and preserve or update the links between project files?
      Thanks!
      -Bob C.
    • #478408
      BobC, good question. Go ahead and move the projects and resource pool to the new location. Then do the following:
      * Open the resource pool and all projects you want to link (or a few at at time)
      * Select Resource Pool / Share Resources, select each of the existing links and break the link
      * Open each project you want to link, select Share Resources, and reselect the resource pool
      Hope this helps…
    • #478424
      Jigs Gaton
      OR use a cloud service that honors ur local file system, like Dropbox and many others. Install that, and you should not have to re-link anything. (Other issues arise, but related to the cloud in general).This may be a useful tact if you have hundreds or more files to relink.
    • #478489
      Eric Uyttewaal
      Hi, I would like to add what Larry and Jigs wrote. The linked files appear in the Microsoft Project interface as if they are absolute path references (i.e. “C:\My Documents\MyProject.MPP”), but, in fact, they are relative path references (i.e. “Look in the same directory/folder for this file” or “Go one directory/folder level up and then one level down into “\My Projects” to look for this file name”). This means that, if you move a whole system of linked files from one directory/folder to another directory/folder, you would never need to re-link those files.
      BTW I describe in detail how to work with linked files and shared resource pools in my textbook ‘Forecasting Programs’. Thanks!
    • #478934
      Bob Cunningham
      Larry, Jigs, and Eric-
      Just wanted to post a quick note of thanks! I did as Eric suggested and moved them all together, it worked perfectly. I didn’t have to break & re-create the links.
      -Bob C.
