elapsed days Duration and lag
Home Forums Discussion Forum elapsed days Duration and lag
    • #414275
      Carlos Santos
      Hi
      I m using MS Project 2016 and can not set elapsed days
      When try to set 10ed in the task duration, the warning is “do not support this duration format”, same in the lag time.
      Can anyone help me?
      Regards,
      Carlos
    • #414278
      Carlos, this should work and always has in Project, and I don’t know of any option that would prevent it from being available. You might check your calendar for anything strange. Is it happening on only one project or all projects? Can you send the project to another user and see if they have the same problem? Just trying to give you some thoughts to start researching. Hopefully someone else has some ideas.
      • #414288
        Carlos Santos
        Hi Larry
        I found the problem.
        My MS Project version is in Portuguese, so is not ed but dp.
        I did not read the warning with the proper and carefully attention.
        My apologies.
        Another lesson: read carefully all MS Project warnings.
        This afternoon I will post another issue regarding tracking progress tasks with work and costs assigned.
        I will appreciate your comments, if possible.
        Regards,
        Carlos
