Change of software
Home Forums Discussion Forum Change of software
    • #407642
      Lina Ostoukh
      Hello, I was wondering if there is any way to implement Guest portal in Microsoft Projects with Client Approval similar to this software https://www.easyprojects.net/project-management-tools/ . I’ve just switched the job and now I need to adjust to the new PM software as a result, so I use Easy Projects as a point of reference. Thank you all
    • #407644
      Lina, my first question is whether you are using Project Server, Project Online, or just Project…and what version. For Project Server it can get complicated, and I’m not the expert on this subject. My understanding is that you will need an Extranet and then set them up in Project Server. Project Online is easier, and as a result of a recent enhancement. For Microsoft Project I’m thinking synch the project to SharePoint and then go with the Extranet solution.
      I’m hoping someone has a clearer answer for this. Good luck…
    • #407685
      Lina Ostoukh
      Thanks for the quick reply. I’m now using Project Server, and for now, it’s a completely new experience for me. I’ll do a reading and a research on this
