Resource Type In Gantt View
Home Forums Discussion Forum Resource Type In Gantt View
    • #410284
      Mike Levine
      I’ve created a Gantt View for task planning and I’ve set up the resource sheet with the correct [Resource] Types (e.g., Work, Material, Cost). However, for reasons that I don’t understand, when I insert the resource type in the Gantt view, the field does not populate.
      MS Project Professional 2016.
      Mike
    • #410286
      Mike, can you please provide a bit more information (insert steps, specific results). The scenario you describe seems very basic without understanding more about what you are doing.
    • #410287
      Mike,
      Resource Type is a resource field. It’s available in Task views but it only shows data when you use a task view such as Task Usage. In a Task Usage view, Resource Type is populated for each resource assigned to the task. But you’ll also notice that even in a task usage view, Resource Type does not populate at the task level. That’s because Resource Type is not applicable at the task level. Hope that helps.
    • #410288
      Mike Levine
      Daryl & Larry,
      Thanks for your responses.
      Daryl, I came to the same conclusion yesterday after posting (here) and after doing more testing.
      I think MS can do better with identifying these types of “design constraints” and in the help. The field [Resource Type] is available to add to any Gantt view and hovering over the field the help doesn’t indicate the particular constraint of “only available in a task view.” In addition, you can display resource name, resource initials in any Gantt view.
      Example: Resource Type
      Again, I’m grateful for your response.
      Mike
    • #410289
      Mike Levine
      Make that “… only available in resource view.”
