Project 2013 Import Wizard
Home Forums Discussion Forum Project 2013 Import Wizard
  • This topic has 2 replies, 2 voices, and was last updated 9 years ago by Shannon.
    • #394016
      Shannon
      We have recently upgraded to Project Server 2013. Several users have local project files that will need to be uploaded to the server. In previous versions we have used the Import Wizard. Although we select to save the file using the Import Wizard all we get is a blank pane on the left side of the screen where the wizard should appear. Does anyone know what causes this or perhaps how to fix it?
    • #394027
      I haven’t heard of that issue but try this. Go to File / Options / Quick Access Toolbar and select the Import Project option. Try using this instead of the save as option. Like I said it shouldn’t make any difference and more a shot in the dark but let me know if you get any different behavior.
    • #394092
      Shannon
      I had the same thought and tried that button as well. No luck.
