Project 2013
Home Forums Discussion Forum Project 2013
  • This topic has 1 reply, 2 voices, and was last updated 8 years ago by Anonymous.
    • #410778
      Randall Ball
      Hi, using the reporting tools, I have created several nice reports that show status of projects and by resource. However, anytime I add a task, it adds that task, and occasionally others, to all the other charts. How can I add a task via the task sheet and ensure it only adds to the appropriate chart. I currently has to go back and reselect the right options for every chart. Any insight is appreciated.
    • #410779
      Randall, the behavior you are seeing doesn’t sound right, but I haven’t used reporting recently so I don’t know if a bug might be in play here. Just as a test, try selecting F9 to recalculate the project and see if that helps. Project is normally calculated automagically but can be changed in options. Also check to make sure you are on the most recent update. Otherwise I don’t have any answer for you.
