Options for Selecting more than one Outline Code
Home Forums Discussion Forum Options for Selecting more than one Outline Code
    • #490929
      dcumming
      Hi – newby on the group, relatively new to MS Project
      I’ve set up an Outline Code to allow values to be selected from a pick list. What I’d like to be able to do is select more than one, ie two values from a picklist for one activity
      Is there a generally recognised best way of doing this?
      David
    • #490931
      Unfortunately, you can’t do it. Custom fields and outline codes, in general Project, doesn’t allow you to choose more than one value in the list.
      You can use multiple fields and make a selection in each one and then combine the data in another field. As an example, you’ve created a lookup in three Text columns (Text1, Text2, and Text3). A choice can be made in Text 1 only, in Text 1 and Text 2, or in Text 1, Text2, and Text3.
      Customize the field Text4 enter the formula:
      [Text1] & ” ” & [Text2] & ” ” & [Text3]
    • #490933
      dcumming
      Thanks Sai – i feared that might be the case
      but thanks for letting me know
      David
    • #490967
      GW
      Quality articles iis the important to attract the users
      to pay a quick visit the web page, that’s what this website is providing.
      블랙잭사이트
