MS Project 2016
Home Forums Discussion Forum MS Project 2016
  • This topic has 2 replies, 2 voices, and was last updated 8 years ago by Stergios Kokkoris.
    • #410767
      Stergios Kokkoris
      Dear MS Project 2016 users,
      I am thinkint to switch to MS Project 2016 version from 2013 which I currently use.
      Could you please give me a piece of advice about that?
      Thank you in advance.
      best regards
    • #410768
      Jigs Gaton
      Stergios, for most users, there is no real difference between using one over the other. But you can install both and run side-by-side to test out your existing projects for problems. The only problems I discovered during my transition was that some add-ins that I used did not work without an upgrade to the add-in. One other area to look into is VBA or macro-heavy projects, which may break… but I did not run into that at all. Best!
      Jigs
      • #410769
        Stergios Kokkoris
        Thank you Jigs, I appriciate your help.
        kind regards
        Stergios
