Is there any way to modelessly view Notes that doesn’t waste screen space
Home Forums Discussion Forum Is there any way to modelessly view Notes that doesn’t waste screen space
Viewing 7 reply threads
    • #477193
      Dan Schaeffer
      Is there a way to keep the notes pane open without using the Details/Task Form pane? I use notes extensively (I dump status emails on tasks directly into it) and I like to be able to see more than a few lines at a time but that means close to 25% of my screen space is wasted when I’ve got the details pane open. Is there any other way to modelessly view the Notes that I’ve missed?
      Dan
    • #477216
      Jigs Gaton
      SURE DAN, just add the notes field to any view, such as the Gantt, and you can just scroll the screen and see / edit all the notes from the view. Best,
      Jigs
    • #477222
      Dan Schaeffer
      Jigs,
      If I’m understanding you correctly that would give me a tiny window through which to view the notes, would it not? Also I’d be limited to viewing only the first 255 characters of the notes. I’d like to have a large display of the notes.
      Regards,
      Dan
    • #477226
      Jigs Gaton
      Ha, yes, that will put the first 255 characters of note data in a cell, The only other think my feeble brain can think of is to create a custom report using the notes field only… that might do it, not sure 🙂 Give it a try!
    • #477293
      Ismet Kocaman
      Dan,
      – By using the key sequence <Shift+F11>, open two windows of the same project plan file, get rid of the Timeline if the default new view includes it.
      – Arrange two windows (Project_File:1 and Project_File:2) vertically so as to share the application space, then open the Task Form/Notes on the right,and open another sheet view that you want on the left. But they won’t be interactive like it happens in a combination view.
      I use this configuration all the time, and if you have two monitors, you can extend the Project application window toward the 2nd screen. I hope this works.
      Ismet Kocaman
    • #477353
      Dan Schaeffer
      Ismet,
      That’s close enough! Thank you!!
      Are there any synchronization issues I should be worried about?
      Dann
    • #477354
      Jigs Gaton
      yes, Ismet rocks. Another thought that I had was to use Evernote in another window, and link to it from the notes field…
    • #477361
      Ismet Kocaman
      It is easy to test, as follows:
      – Open the Task Entry view with Notes detail on the left window
      – Open the Task Form view with Notes detail on the right window
      – Select the same task on both windows such that both show the same task notes
      – Enter some text into either Notes box and and click OK, the entry will appear on the other box.
      Hope this works.
