Insert Subprojects, Project 2016
Home Forums Discussion Forum Insert Subprojects, Project 2016
  • This topic has 1 reply, 2 voices, and was last updated 7 years ago by Josh Logan.
    • #412306
      I have a master project withe 100 activities/tasks with a milestone task of conclusion.
      Later i insert a small subproject (5 tasks)
      I would like to have dependencies between the last tak of my master project and my subproject summary task.
      Then if i track the tasks of master project will have automatically inpact on the subproject inserted.
      Other way How can i constraint (start and finish) the subproject with the master project?
    • #412518
      Josh Logan
      Carlos –
      Insert the sub-project, then create the dependency links between the master project’s tasks and the sub-project’s tasks
      Ideally, maintain the sub-project as linked, to the master project (make updates to the linked version of the sub-project); otherwise, the links may go away if you delete/re-add a modified sub-project.
      To create the link:
      1) Select the predecessor task
      2) Hold the CTRL key
      3) Select the successor task and release the CTRL key
      4) Press the “link the selected tasks button” key (Ctrl + F2) in the Task Menu.
