Insert & Publish Subprojects into Multiple Master Projects
Home Forums Discussion Forum Insert & Publish Subprojects into Multiple Master Projects
  • This topic has 1 reply, 1 voice, and was last updated 5 years ago by Dan Schaeffer.
    • #418615
      AJ Beers
      I am working with MPP 2016 Enterprise. I have 3 subprojects that I would like to link to 4 master projects. One of the master projects (Project 1) will contain all 3 subprojects, and then the other 3 master projects will each contain one of the subprojects. So far so good. I have given Project 1 read/write access and the other master projects read only access to the subprojects. The plan is for me to be able to view/edit the subprojects from Project 1 and it will automatically update to the other master projects. I am running into an issue while publishing Project 1. I get this error:
      “The current project has inserted projects that are present as inserted projects in other master projects as well. A project cannot be inserted into multiple published master projects.”
      Am I stuck or is there a way around this? Thanks in advance for any help!
    • #418643
      Dan Schaeffer
      I haven’t got an answer for you, but What’s the motivation behind the read-only master projects? Seems odd to have a master project with only a single sub-project.
