Has Anyone Done Any Comparison with SAP Project System (PS) vs. MS Project 2010?
Home Forums Discussion Forum Has Anyone Done Any Comparison with SAP Project System (PS) vs. MS Project 2010?
  • This topic has 3 replies, 2 voices, and was last updated 8 years ago by David Coffey.
    • #5325
      Hi All,
      I look forward to your thoughts on this topic.
      Regards,
      Jeffrey
    • #90610
      Darijo
      Hello Jeffrey,
      I am looking for an answer on the same question “… Comparison with SAP Project System (PS) vs. MS Project 2010?”
      Have you ever received any answer or do you have any references to information for share?
      I would appreciate.
      kindly
      Darijo
    • #128402
      Randy Johns
      I used the SAP project module for about 6 months in 2012. I found it to be quite cumbersome and not user friendly. That could have been the way my employer set it up or because the training was given in half Spanish and half English. Outside of the delivery method or set up, the interface was simply cumbersome. Compared to MS Project 2013/2013, SAP is not as valuable as a PM tool, in my opinion, as MS Project. There are tools out there that are a bit more robust that MS Project but Project is the most common tool out there. Especially with 2013 being retooled, I am quite happy with it.
    • #410290
      David Coffey
      SAP is an ERP solution for the entire business processes such as administration, budgeting, accounting, purchasing, management, etc. It originally was written to control investments and the cash flow for projects.
      MS Project is focused around project planning, scheduling, control and monitoring. It is more of physical monitoring of project rather than financial monitoring. There is element of cost monitoring in MS Project but it is still not in detailed format and exhaustive as SAP. At the same time SAP is not as user friendly and too many steps to complete a simple process. Whereas MS Project is lot more simple and easy to operate. Most of the project manager and engineer working on site find it easy to manage project using MS Project.
      There is another tool coming up in the market called TIEMCHART. Its founder is having an experience in SAP and build the platform that takes the advantage of both SAP & MS Project into one nice web based platform. Try them out if you are looking for an alternate solution https://tiemchart.com/
