Gantt view – show split when resource is on vacation
Home Forums Discussion Forum Gantt view – show split when resource is on vacation
  • This topic has 5 replies, 2 voices, and was last updated 7 years ago by Kelly Foo.
    • #5309
      I’ve searched the forum and didn’t see this question before, although it’s pretty basic:
      I assigned a single resource to a task. My developer is going on leave for 6 weeks (!) and I updated his calendar. However, I don’t see a split in the task for when he’s gone – nor do I see any reflection of his leave in the resource view. I’m hoping to show a dotted line (split) in the task without using the Stop and Resume fields. Why is Project showing the task as a solid blue line?
      Not a terribly eloquent description of the problem, but it’s late and I’m tired. Help?
      Respectfully,
      Sarah
    • #7093
      Hi Sarah,
      The Gantt chart shows (by default), the duration of the task, rather than an reflection of the resource’s allocation to that task on any given day, which is why you see the task spanning weekends aswell.
      Depending on what you want to show, you have a couple of options.
      1. Use stop and resume as you suggested
      2. Use SPLIT task to manually split the task.
      3. Use the Resource’s calendar to display non-working time in the Timescale – thereby showing their non-working time.
      4. Put a Note on the Gantt chart, linked to the date saying the resource is on holiday.
      BR,  Ben.
    • #7094
      Ben – the SPLIT TASK was exactly what I was looking for! Thanks for both your answer and your timeliness in replying. You saved me.
      Sarah
    • #7095
      Wow, always happy to have saved a lady!  🙂
    • #413312
      John Wayman
      I have tried the split, and have introduced one into a task, but I can’t drag it to the date I want to and have it stay there. I drag it across, 1, 2, even 10 days and it simply returns to the date I originally inserted it. If I drag the right-hand side of the split, it removes the split altogether.
      Am I missing something?
      John
    • #413408
      Kelly Foo
      Project Scheduling and Scheduling Risk Analysis Course
      Tagline
      Identify and examine the impact of risks to your project plan so they can be mitigated for better results.
      Workshop Overview
      Attendees will demonstrate the principles of project scheduling, from simple forward pass / backward pass and early dates to advanced use of constraints, resources, calendars, statusing. They will show methods of schedule problem diagnoses and discover scheduling principles to critical path, total float and horizontal and vertical traceability. The course will show these principles on classroom exercises using manual techniques. They will be able to understand and present the issues and techniques for collecting high-quality quantitative risk analysis data using confidential interviews. The attendees will complete several case studies by hand, each illustrating in simple terms an important principle just presented. Screens from Primavera P6 and demonstrations of Primavera Risk Analysis® and Polaris® present the principles so the attendees can return to their desks and implement the case studies on their software. This course covers parts of the Project Schedule Management knowledge area and the Perform Quantitative Risk Analysis process of the Project Risk Management knowledge areas of the PMBOK® Guide.
      Key Benefits of Attending
      • Find out how much contingency of time would be needed as opposed to relying on a project schedule alone
      • Determine how much contingency of cost including the impact of schedule on cost is needed
      • Understand the basics of scheduling compliant with best practices and to identify scheduling problems needing attention
      • Learn why the Risk Register is usually incomplete and how to complete it using confidential risk interviews
      • Learn about Monte Carlo simulation and how to interpret the results of a simulation
      • Learn the benefits of using the Risk Drivers method to model the effect of root cause risks on the schedule
      • Learn how to prioritize the risks to prepare for the risk mitigation workshop
      Who Should Attend
      Project Control Managers, Scheduling Managers, Risk Managers, Cost Estimators
      https://www.miceglobal.com.sg/events/257.html
