Enterprise field name constraints
Home Forums Discussion Forum Enterprise field name constraints
  • This topic has 3 replies, 2 voices, and was last updated 5 years ago by Anonymous.
    • #418481
      Using MS Project Server (Project Online 2016) and trying to find out if there are any Enterprise field name constraints for Task related fields. I ask because we recently (2 weeks ago) created a new Task field “Application”, refreshed Power BI to see the new field, populated it in MS Project and expected to be able to report on it in Power BI. We can see the field in PBI but no data has pulled across. The only reason we can come up with is a naming constraint, but have been unable to find any documentation relating to that.
      Any pointers most gratefully received.
      Cheers
      Brian
    • #418482
      Brian, I do not know of any constraints and don’t have an answer to your question. I’m responding in case you get an answer from others. Good luck…
    • #418486
      Hey Larry, thanks for the response, I’ve been doing some testing myself and it looks as though, if you call a new Task field Application and make it a text field it’s auto assigned to one of the Text1-20 fields, which don’t get exported to Power BI. Naming the field to something else, Prj_Appl for example, it picks up as a plain field without a problem.
      I guess we can close off this query
      Rgds
      Brian
    • #418487
      Thanks Brian, good to know. It’s not a reserved word in either Project or Project Online but PBI must have a separate constraint.
