Database Corruption in Project 2003
Home Forums Discussion Forum Database Corruption in Project 2003
    • #5168
      I realise this is old hat but my client is using Project 2003.  We have a data corruption that is resulting in remaining work displaying as -1,666,666,666,67 days!  Not surprisingly Project reports this as an error unfortunately it is also important that I maintain the Task Unique ID’s so I cannot just rebuild the plans – export to XML does not appear to work (because it maintains the corruption).  Whilst not massive this is impacting 3 linked plans totalling about 2500 lines.
      Is anyone aware of a solution to this issue?
      Many thanks
      Nigel
    • #10628
      Well I’ve kind of answered my own question.  Here is a solution, but it wasnt ideal:-
      Remove all work from plan that showed errors
      remove the inserted plans
      Save as XML
      Edit XML file to set silly work/remaining work values to zero
      create project from XML
      recover views/fields/tables etc.
      re-insert plans
      check the external links
      re-cover work
