Change the Color of a Cell when Task Complete
Home Forums Discussion Forum Change the Color of a Cell when Task Complete
  • This topic has 6 replies, 4 voices, and was last updated 8 years ago by Steve.
Viewing 6 reply threads
    • #380457
      daniel
      When a task is complete a check mark appears in the ‘indicators’ column. Is there any way that I can also arrange for a cell to turn green? For example, upon completion it would be great if the ‘task name’ cell went green to make completion more noticeable for those uninitiated with MS Project.
      Thanks!
    • #380576
      Daniel, all I can think of is to test % Complete = 100% or test Status equal to Complete. I’m thinking you can use VBA against these actual columns to do what you are asking, but I’m not a VBA developer so not positive. Hope that helps…
    • #380589
      daniel
      OK, thanks Larry!
    • #380728
      Andy Forrester
      daniel,
      There is a standard filter called Completed Tasks.
      You can set it as a Highlight Filter and set Highlight text to show green background
      This will show all completed tasks cells as green
    • #380729
      daniel,
      btw you have to re-apply the filter each time you mark another task as complete
    • #410752
      Steve
      I am having an issue. The filter works great, EXCEPT one task the task name is not highlighted. What am I doing wrong?
    • #410753
      Steve
