approved and unpubished project task time
Home Forums Discussion Forum approved and unpubished project task time
  • This topic has 7 replies, 1 voice, and was last updated 3 years ago by Anonymous.
Viewing 7 reply threads
    • #4845
      is there a field on the reporting database or on another database that shows if a project has MY TASK approved actual hours and unapplied / not published?  i am looking to create a report of all projects that need to be published to apply the actual approve my task hours.
    • #6011
      Yes.  In PWA, do the following:
      1.  Click on Task Updates.
      2.  Click on the drop-down Go-To list.
      3.  Choose Applied Requests and Errors.
      4.  You will get a listing of all accepted / rejected task updates.
      5.  There is a column that indicates published Y or N.
      6.  You can click on any row to view the actual details from the resource’s entry for the project/task.
      Best wishes,
      Tom H.
    • #6012
      Thanks.  This will show the projects for which I am the project manager.  I need to create a list of all projects with unpublished time for all projects in the application.
    • #6013
      You will need to create a group id that allows you to view all projects, not just the ones that you own.  The admin will have to configure the group id.
    • #6014
      I am the administrator and have full rights to the site.
    • #6015
      I assumed you were the owner / status manager for all the projects.  I am not sure of a way to view this information across all PM’s.  My thoughts are a PSI tool to query the draft database, since this houses all non-published project info.  Perhaps Project Experts or some other place has written something like this.
      Tom
    • #6022
      i was assuming that i would need to write something against the database, but i am not sure what database and table to reference?
    • #514903
      Interesting I have less knowledge about databases.
